Ansys Learning Forum Forums Discuss Simulation Fluids Seeking Guidance on TUI Commands for Parametric Study in Ansys Fluent Reply To: Seeking Guidance on TUI Commands for Parametric Study in Ansys Fluent
I would always build a model using the GUI and then use TUI commands to save/update the reports once a model has run. Creating all of the plots etc using just TUI commands, to then save the object, combine objects etc is "simple" but a lot of work. I'm also the person responsible for writing1500 line journal files to set up and then post process models.
Everything will be in the /display or /report section, but be aware some of the Parameter commands may not be fully set up as it's a relatively new feature and I've seen missing GUI/TUI commands a few times as we've added new features.Â
