Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The Problem of Pressure Data Transfer between Two Fluent Computing Models › Reply To: The Problem of Pressure Data Transfer between Two Fluent Computing Models
October 12, 2023 at 5:36 am
Essence
If you want to manually add the name to the profie you can use File > Export/Write > Profile and enter the desired name. But if you automate the process it is better to use Execute commands. You need to use -%t for TUI commands.
Did I answer your question?
