The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Ansys Learning Forum Forums Discuss Simulation Fluids Calculation of Swirl Velocity Reply To: Calculation of Swirl Velocity
anxo.ramos.fontelo
Hi, I am trying to simulate an actuator disk to show results as a drone propeller. Firstly I calculate the pressure drop of the actual drone propeller (MRF) between upper and lower surface (see image) and now I am trying to set this pressure drop onto the disk actuator simulation by setting a plain surface with the diameter of the propeller as a fan. My main problem is that if I only set the pressure drop as a constant I do not get accurate results, so I would like to know if I should also set the swirl – velocity specification on the fan dialog box and if so, how can I get those parameters from the actual propeller simulation? Since I am a bit lost right now.
Thanks in advance.
