Ansys Learning Forum Forums Installation and Licensing Ansys Products 2D porous Medium non-thermal equilibrium problem Reply To: 2D porous Medium non-thermal equilibrium problem
nandacd
Hi Rob
So I tried plotting the velocity profile, for both the models of laminar and k-epsilon. This is what I have gotten. I am attaching the velocity profile in this reply. So the issue here is the turbulence generated in fluent is not very significant that there is much difference in laminar and turbulent models.
But I have also tried the same simulations without the porous medium and just a simple pipe flow. There I did not find any issues with the velocity and temperature profiles, they were as expected for laminar and turbulence model
