Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › No Change Life-Damage Result in nCode DesignLife › Reply To: No Change Life-Damage Result in nCode DesignLife
October 3, 2023 at 4:13 am
Thank you so much.
My distance between each acceleration is 0.2 seconds. The simulation sees this as 1 second, not 0.2 seconds, but you said the time is unnecessary. Actually, I entered 90000 acceleration data as time-series input. I’m a little confused here. Is not enough?
Is it true analysis? Normally, I would put these two loadings in a single structural analysis, but it appeared as a single stress result in the fatigue analysis. So I split this in half but I’m not sure it’s correct. Otherwise, I cannot select the moment as ‘static’.
