Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Apply rotational stiffness to a base › Reply To: Apply rotational stiffness to a base
October 2, 2023 at 1:28 pm
Moustafa El-Sawy
If I need to apply springs in all 6 directions to the base of my solid elements, is there any way to accomplish this (individual nodes not the entire base with a single value).
I was thinking of adding shell elements to the base that share the same nodes as the solid elements and this will enable those nodes to take moment? Do you think this will work? In this case I was planning on assigning these shells as massless and with small stiffness to not affect the dynamic behavior of the structure.
