john legend
https://drive.google.com/file/d/1x-K26eOqndJXMgkUgxH6lzRKeuA58oNz/view
hi today i do the simulation according to your methld.but whether or not add the thin wall thinness .the simulation result is completely same .i think something wrong in my undersatanding and precess.Could you take a look at my case by link to download.It just 60mb. thanks very very much.(probably 2023r1 cannot open it smoothly ,but 2020r2could smoothly open it . )
heat exchanger working process:
1.bafflesset 0.3mm and material s(poly).baffles set 0.3mm materal s(poly)
2.set separated wall (0.3mm &material s)set separated wall 0.3mm
