Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Beam profile dependence › Reply To: Beam profile dependence
September 30, 2023 at 3:30 pm
Hi Javat,
I haven’t found anything to disable the dependency on the profile. You can only edit the profile and save it to a new file in your system, and then you can use it. There are standard profiles available there, so you can use them if they fulfill your requirements. Â
Sampat
