Ansys Learning Forum Forums Discuss Simulation General Mechanical enthalpy at melting single bead parametric simulation in ansys additive Reply To: enthalpy at melting single bead parametric simulation in ansys additive
Zoi Stavrothanasi
If you want to define the enthaly of a material you have to access the Engineering data, then sletect Thermal from the Toolbox and finally drag Enthaly and drop it in the property section. Hope this helps!
ZoiÂ
