Ansys Learning Forum Forums Discuss Simulation Fluids Residuals contours Reply To: Residuals contours
You can't plot the residuals (good idea though). Mass balance is available in the contour plots, focus more on the high/low parts of the scale over the values.
Depending on what is causing the problems I also suggest looking at velocity and temperature contour plots with node values on and then off. You're looking for badly resolved gradients.
How are the monitors looking?
