Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Add a new material in HEAT thermal material database › Reply To: Add a new material in HEAT thermal material database
September 22, 2023 at 7:14 pm
Hi, You can import new material : Material Database in Finite Element IDE (CHARGE, HEAT, DGTD, FEEM, MQW) – Ansys Optics
This post also help you to understand adding new material :Â Ansys Insight: How to add new material into the optical material library
Thanks and regards
Devika
