Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Multiphase simulation using VOF › Reply To: Multiphase simulation using VOF
September 21, 2023 at 11:17 am
Can you check the inlet conditions please confirm is it velocity inlet or pressure inlet conditon etc,also check for the temperature conditions provided as energy equation is diverging)? Additionally you can check with different Pressure-Velocity couplings scheme for example SIMPLEC, PISO etc
