Ansys Learning Forum Forums Discuss Simulation General Mechanical User defined result with the PNUMMAT expression Reply To: User defined result with the PNUMMAT expression
Govindan Nagappan
This is probably a limitation of PNUMMAT that it only shows material assignment done under /prep7
Can you use /PREP7, change the material and go back to /SOLU?
Another way to check material assignmnt is by selecting the "solution" branch, go to "Worksheet" and show "Material and Element Type information"
