Yuanyuan Xiao
方法1
Journal文件命令如下:
/file/read-case cyl10.cas.gz
/solve/initialize/hyb-initialization
/file/start-transcript resi-demo
/solve/iterate 1000
/file/stop-transcript resi-demo
/file/write-data cyl-10.dat.gz
/exit
这样,计算时在工作路径下就会出现resi-demo的文件,该文件记录了残差,并实时更新。
方法2
采用如下命令:
/file/read-macros scmdemo.scm
/solve/set/time-step 0.1
/solve/execute-commands add-edit command-1 1 iteration  "/file/read-journal joudemo.jou"
/solve/execute-commands enable command-1
/solve/dual-time-iterate 100 30
/file/write-data cyl10.dat.gz
/exit
1joudemo.jou文件的内容如下:
(do
((i 0 (+ i 1)))
((= i (length (solver-residuals))))
(format port "~a ~2t" (cdr (list-ref (solver-residuals) i)))
(newline port)
2scmdemo.scm文件的内容如下
(define port)
(set! port (open-output-file "output.dat"))
(do
((i 0 (+ i 1)))
(format port "~a ~2t" (car (list-ref (solver-residuals) i)))
(newline port)
