September 5, 2023 at 5:41 pm
Guilin Sun
Once you use the circular polarized excitation in the simulation, everything is taken into account by FDTD. You do not need to worry about nonlinear optical process or superpostion. The physics occurs naturely with FDTD which solves the Maxwell Equations with proper material models, as long as the boundary conditions are set correctly.
