My simulation works correctly when I use a simple hollow capped rod, but when I apply the same approach on actual barrel geometry, Floating Point Exception error occurs. Can you please guide regarding it.
Please Login to Report Topic
Please Login to Share Feed
Edit Discussion
You are navigating away from the AIS Discovery experience
