August 22, 2023 at 7:47 am
DMARATHE
Hello Yushu Zhao,
Thanks for posting your query on Ansys Learning Forum. I could see that mentioned setup steps and expression are correct to compute the quality factor of the structure.
However, I suspect issue with some settings especially Port creation. This will have to check with the actual model. If you have access to Ansys Techical support, please raise a service ticket and support engineer will connect you to resolve the issue.
Thanks.
