Jiwon Kang
Bbp_participant
Thank you for reply.
As I know, in order to carry out a collision simulation with residual stress of the film, it is necessary to map the stress with a Static Structure and connect the result with explicit dynamics.
And I understand that in this case, the same load must be applied to Explicit Dynamics so that the load can be appied normally to the module.
Is it true what I know?
Is it impossible to import the initial load with stress in Explicit Dynamics?
Jiwon Kang
