Armin
Hi Durgesh,
Is there a fillet in your model in the region indicated by the red circle? The element size may be too coarse to capture deformation of such a tight fillet. If you're seeing stress values that you believe are un-realistic (for example, artificially high), please check the video below where the causes and remedies for this problem is discussed in more detail:
Understanding and Dealing with Artificially High Stresses — Lesson 3 - ANSYS Innovation Courses
