peteroznewman
Bbp_participant
Hi Sterling,
In SpaceClaim, on the Design tab, use the Combine tool. Select the block as the Target then select the sphere as the cutter object. It will subtract the two and leave you with a solid of interference and the block will have a spherical cavity in it.  You can delete the solid of interference if you don't want it.
You can create a surface from the cavity face by simply selecting the face and type Ctrl-C, Ctrl-V to copy/paste the face and create a surface.
Peter
