Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › set up a structure completely above the water in aqwa › Reply To: set up a structure completely above the water in aqwa
July 27, 2023 at 2:41 pm
You should not need any special settings for the bridge structure: as long as it is non-diffracting, the Aqwa solver will not give any error due to the overlapping elements at each end of the bridge.
Mike
