July 26, 2023 at 9:59 am
Sakun
Hi NickFL,
Appreciate for the reply and well explanation.
LES simulation ran without diverging and i have set up the simulation for 2000 timesteps with 60 max iteration per time step and delta T is 1e-06. i have attached a pictures of residuals and cL results with LES settings as well. Â
For my case, flow through time is 0.001148s but in the simultion happened only for 0.002s but the results are not suitable for the validation. So does it mean i have to run at least 1s or there is something wrong with my case set up ?
Thank you very much for your time,
