Nilay Pedram
I hope while saving the plots/data you must have 'write>case & data'. Now, you can 'read>case & data' that you previously saved to retain the same residuals and plots.
To plot the residuals, you can find the 'plot' option in residuals setup and same for report definitions.
Hope this helps you.
Thanks!
