July 17, 2023 at 12:07 pm
Zoi Stavrothanasi
Hello Deepak,
The cause of errors with highly distorted elements may vary, and the error messages provide clues to the areas you may need to consider for resolving your non-convergence issue. Firstly, I would suggest refining your model by reducing the element size to capture more details. Additionally, adding more steps through Analysis Settings > Step Controls can help in achieving convergence. Since you are modeling a non-linear problem, activating large deflection via Analysis Settings > Solver Controls is necessary. I hope these suggestions help!
