NickFL
Bbp_participant
The start button is the lower left corner of windows that shows all your applications. It should not matter how you open it. Rob’s key point is that you should close out of all ANSYS applications before trying to open CFD-Post. If you are restricted to one license, opening CFD-Post will be blocked with the same error message you see here.
