Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Translucent internal surfaces+Radiation model › Reply To: Translucent internal surfaces+Radiation model
July 13, 2023 at 12:54 pm
Thank you for your reply.
What is the meaning of interface wall? I defined these surfaces as walls.
When I defined the walls as semi-transparent walls, I can only set the diffuse fraction of walls. The absorption, reflection and transmission can not be set. Please see the photo. The change of wall materials was not work.
Could you help me?
