Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Is there a way to calculate the grinding consumption through FLUENT › Reply To: Is there a way to calculate the grinding consumption through FLUENT
July 11, 2023 at 10:10 am
Fluent doesn't have a grinding model. Fluent can give you parameters that can be used in an experimentally derrived correlation to calculate a grinding rate. So you can do the experiment on a simple, safe system and employ Fluent for complicated, dangerous and expensive enviroments as part of the design process.Â
