Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › LS-DYNA nodout time step › Reply To: LS-DYNA nodout time step
July 10, 2023 at 3:23 pm
Andreas Koutras
Hello, output cannot be generated at time intervals less than the timestep size of the analysis. The smaller output time interval can output a higher frequency of the response. However, the results at the same time instances should be the same in the two cases.
