Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › How to view failed solid elements? › Reply To: How to view failed solid elements?
July 8, 2023 at 12:09 am
With "Show Deleted Elements" turned on, what you should see is all the elements but in their original, undeformed state. As you scroll through time, the elements remain undeformed but the deleted elements will change to a different color to indicate they've been deleted. You won't be able to see deleted elements in a deformed configuration.
