Ansys Learning Forum Forums Discuss Simulation General Mechanical Divergent hourglassing model near bolt holes using Cohesive zone material Reply To: Divergent hourglassing model near bolt holes using Cohesive zone material
wancheng gao
Thank you John!
I tried following your advice and still couldn't get the energies. I inserted cid#=cid under different czm contacts of interest and inserted corresponding command snippet in solution to output the energies for each czm contact. Here shows the messages. Could you please advise me what changes to make?
Thank you!
