Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Temperatur result is higher than the temperatur load ? › Reply To: Temperatur result is higher than the temperatur load ?
July 7, 2023 at 2:21 pm
Also, there is a negative temperature which is non-physical. This issue appears to be the result of using too small a time-step relative to the 2nd order element size. The smallest time-step that can be used is given in Section 3.4.3.2 of the APDL Thermal Analysis Guide. Workarounds are using a finer mesh, increasing the time step or using first order (Linear) elements.
