Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem about Euler beam › Reply To: Problem about Euler beam
July 7, 2023 at 7:43 am
Thank you, Nanda, for your quick and kind reply.
Currently, the link you attached with my academy license is not accessible, but I checked the information about BEAM4 and BEAM188 you wanted to talk about using Ansys Help. As you answered, very small errors may occur in numerical analysis, etc., and I think it is within an acceptable range.
Lastly, can you check the command using beam 4 that I used in the above problem? The picture below is the command used for the above problem.
Thank you! :)
