Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › SpaceClaim Python API: Getting the results of a Check Geometry › Reply To: SpaceClaim Python API: Getting the results of a Check Geometry
The result of an operation returns a booean True or False when directly queried which is indicating whether the action succeded without error, but this is an object that is not boolean and will have many properties/methods below it when queried with dir(). In this case, the important object beneath result is "Messages." It will show it is type Dictionary[IDesignBody, IList[CheckMessage]].
So get messages for the first body this way:
all_bodies = GetRootPart().GetAllBodies()
selection = BodySelection.Create(all_bodies)
result = ApplicationHelper.CheckGeometry(selection)
Body1Messages = result.Messages[GetRootPart().Bodies[0]]
if Body1Messages.Count == 0:
  pass
  #no errors
else:
  for mess in Body1Messages:
    print(mess.ModelerMessage)
    # other objects under mess to get IDs of problem geometry
