Ansys Learning Forum Forums Installation and Licensing Ansys Products installing Ansys nCode 2022 Reply To: installing Ansys nCode 2022
VJ
Where did you get the package from? If it is from the customer portal, there should be only one .wbex file when you extract it.
Launch Workbench > Extensions > Install Extensions > browse and open the .wbex file.
Workbench > Extensions > ACT Start Page > Manage Extensions > Locate 'MechanicalEmbeddedDesLife' and choose 'Load as default'
Relaunch Workbench and you should see the nCode Design Life modules in WB.
