Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Pressure difference of two faces › Reply To: Pressure difference of two faces
July 5, 2023 at 6:02 pm
the difference in the x coordinate can be taken care of by the mapping process. You may not need to change the x coordinates manually. Try without it and see if that helps.
-Aniket
