Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Contact tools does not get solved. › Reply To: Contact tools does not get solved.
July 5, 2023 at 2:56 pm
Hi Durgesh Pandey
Can you please right-click the Connections object and Insert a 'Solution Information'. Then generate the initial contact and post the top of the resulting solution information. Â
Also at the very top of WB Mechanical the license checked out should be given in brackets []. What license was checked out?
Mike
