Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rotational velocity in static structural › Reply To: Rotational velocity in static structural
July 5, 2023 at 9:58 am
Sampat Kumar
In addition, If you want to see the dynamic behavior of the disc from start to end of the time span, then I suggest you to use Transient Structure module. You can actually see the rotational movement of the disc there.Â
Regards,Â
Sampat
