Ansys Learning Forum › Forums › Discuss Simulation › Fluids › can you define the velocity of a region after a specified time? › Reply To: can you define the velocity of a region after a specified time?
June 29, 2023 at 10:31 am
Ansys Fluent also includes a feature that allows you to define your own command(s) to be executed during the calculation at specified intervals.You will indicate the command(s) that you want the solver to execute at specified intervals during the calculation using the Execute command.
For more details you can check fluent user's guide: 33.17. Executing Commands During the Calculation (ansys.com)
Thank you.
