Ansys Learning Forum Forums Discuss Simulation Fluids floating point exception Reply To: floating point exception
Eman Basheir
the the three phases are: Biomass, gas, sand.
the sand is inert and only it is work as heat carrier. the biomass is heated and then it produce the gases , sorry I am begineer I need some details, so you means I have to delete these phases and started with single phase for examle the biomass only ?.
I checked the mesh quality and it is as follow:
Mesh Quality:
Minimum Orthogonal Quality = 2.53196e-01 cell 24135 on zone 4 (ID: 99760 on partition: 2) at location (-4.75776e-01, 1.09642e+01, -1.32245e+00)
Maximum Aspect Ratio = 1.26151e+01 cell 24135 on zone 4 (ID: 99760 on partition: 2) at location (-4.75776e-01, 1.09642e+01, -1.32245e+00)
Kindly advise me.
