Hello everyone, excuse me I'm having an «error object... floating point exception » .Â
The calculation process goes for a while then it stops and I get that message.Â
I'm simulating a fluid flow (biomass byrolysis) using ANSYS Fluent. Kindly see the following error massage:
Divergence detected in AMG solver: pressure correction Stabilizing k to enhance linear solver robustness.
Stabilizing k using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: k Stabilizing epsilon to enhance linear solver robustness.
Stabilizing epsilon using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: epsilon Stabilizing gas-species-0 to enhance linear solver robustness.
Stabilizing gas-species-3 to enhance linear solver robustness.
Stabilizing gas-species-4 to enhance linear solver robustness.
Stabilizing gas-species-5 to enhance linear solver robustness.
Stabilizing gas-species-6 to enhance linear solver robustness.
Stabilizing temperature to enhance linear solver robustness.
Stabilizing temperature using GMRES to enhance linear solver robustness.
temperature limited to 1.000000e+00 in 99842 cells on zone 4 in domain 2
temperature limited to 1.000000e+00 in 99842 cells on zone 4 in domain 3
temperature limited to 1.000000e+00 in 99842 cells on zone 4 in domain 4
Stabilizing vof-1 to enhance linear solver robustness.
Stabilizing vof-1 using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: vof-1 Stabilizing vof-2 to enhance linear solver robustness.
Stabilizing vof-2 using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: vof-2
WARNING: Invalid cp (0.00
0===============Message from the Cortex Process================================
Error at Node 3: floating point exception
Compute processes interrupted. Processing can be resumed.
000e==============================================================================
+Error at Node 2: floating point exception
Error at Node 1: floating point exception
00
Error at Node 0: floating point exception
J/kgK) for carbon-solid at temperature -nan(ind) K
Thanks
