Aniket
Hi Ramiro,
First of all very well-written question! Kudos for that! There was an issue in older APIs of FilterByBoundingBox which is fixed in 2023 R1.
so something, as follows, would work in 2023R1:
from SpaceClaim.Api.V23 import *
PartSel = Selection.Create(GetRootPart())
faces = PartSel.ConvertToFaces()
BoundingBox = Box.Create(MM(-30),MM(-30),MM(-30),MM(30),MM(30),MM(30))
facesInBoundingBox = faces.FilterByBoundingBox(BoundingBox)
You may want to upgrade to 2023R1.
If that's not possible, possibly you can loop through faces and check their centroid such as:
GetRootPart().Bodies[0].Faces[0].EvalMid().Point
-Aniket
