Ansys Learning Forum › Forums › Discuss Simulation › Fluids › why don’t need to set any property ignite point in non-premixed combustion › Reply To: why don’t need to set any property ignite point in non-premixed combustion
March 1, 2023 at 8:17 am
So i was simulate a micro gas turbine the fuel injection was set as mass flow inlet :0.0096 kg/sï¼›mixture fraction set 1ï¼›total temperature 300k.And the air was set as mass flow 0.473 kg/s of oxidizer ï¼›total temperature 430k
the speices model i chose [non-premixed combustion chemical equalibrium],after caculation the result temperarure appear over 2000k.so why the temperature can be such high?is there any property burning point can be set?
