Ansys Learning Forum › Forums › Discuss Simulation › Fluids › part of residuals smoothed and turned to a straight line, why? › Reply To: part of residuals smoothed and turned to a straight line, why?
February 27, 2023 at 3:02 pm
You may want to increase the number of iterations per time step (at least initially), to see if this helps stabilize the solution.Â
Also I see that you have a dynamic mesh set up, make sure your time step is small enough to ensure that your moving boundary does not move more than 1 cell width per time step.
