Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Help!, Thermal simulation DED process › Reply To: Help!, Thermal simulation DED process
February 27, 2023 at 12:15 pm
Yes, All the bodies in tha named selection have elements in them, Mesh size is 3mm, which is same as the layer slicing height.
No, I wasnot able to do manual clustering. & was getting the same error "“Error:  Node 0 is not defined"
