Ansys Learning Forum Forums Installation and Licensing Ansys Products Finding inductance and capacitance using S,Y,Z parameters in HFSS Reply To: Finding inductance and capacitance using S,Y,Z parameters in HFSS
Atonal Wilson
HFSS™ uses a numerical technique called the Finite Element Method (FEM). This is a procedure where a structure is subdivided into many smaller subsections called finite elements. The finite elements used by HFSS are tetrahedra, and the entire collection of tetrahedra is called a mesh. A solution is found for the fields within the finite elements, and these fields are interrelated so that Maxwell’s equations are satisfied across inter-element boundaries. Apart from this if you want to learn something new then react native online course is designed for JavaScript and React developers who aspire to learn mobile building skills. By following this course, you will expand your React and JavaScript knowledge, learn some concepts of functional programming, and prepare to enter the mobile world.
