Ansys Learning Forum Forums Discuss Simulation Electronics PMSM braking with braking resistor Reply To: PMSM braking with braking resistor
DELI
hi,
no, the excitation will be either current, voltage or external, it will not switch from one to another. But you can setup the circuit design with switches, open braking resistor and switch to another voltage source.
Motion will be handled in motion setup in Maxwell design, it could run at constant speed or changing speed. And mechanical transient could be considered as well.
