Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › What theory or solution that ansys use for analysis the part damage? › Reply To: What theory or solution that ansys use for analysis the part damage?
Hi Armin
Could you please to advised ?
I already check with you recommend but normally i didn't additional detail in "Engineering data" such as failure data.
But after program analysis i saw some element show red color and part do change condition.
I suspect that point liked part damage. Then i would like to know how program calculate that point do damage ?
Because i would like to know liked theory or solution that program calculate and report result as same animation show ?
Can you explain from my question ?
from my picture after analysis some part show hole
