Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Adaptive mesh while using sweep operator › Reply To: Adaptive mesh while using sweep operator
February 23, 2023 at 3:27 pm
DELI
hi, I would suggest adding more segments for the edge, and make mesh finer.
You can get the same mesh by linking mesh. First, create a source magnetostatics design and set the desired mesh in this design. Second, create target design, link the mesh in analysis setup (solver tab) and change max number of passes to 1(General tab).
