Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Liquid metal in vacuum › Reply To: Liquid metal in vacuum
February 23, 2023 at 8:15 am
Well, the idea is to see how the vacuum impact fluid behavior (as in my case, the fluid should be projected at the inside top of a circular shaped section, and then evacuated at the bottom inner zone (thus, creating a fluid layer on a rounded shape). We feel like this very low pressure in the chamber will modify the interface behavior with the fluid, leading to a modification of operating conditions (like velocity, temperature, ...)
Thx
