Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › License issue – certificates › Reply To: License issue – certificates
February 22, 2023 at 8:54 pm
You are using the flexlm port, not the ansyslmd port. The ansyslmd port should be a different port, found on the VENDOR line of the license file. Please try using that port.
Also, the variable is ANSYSLMD_LICENSE_FILE, not ANSYS_LICENSE_FILE
